The Crucial (Micron) 2GB modules that I found as reliable on RB1000 do not work reliably on the RB1100.
I tested 3 known good modules yesterday. Two of them caused the RB1100 not to post. The third module seemed to behave well.
I tested two of the bad Crucial modules that would not allow the RB1000 to reboot. Both seemed to work fine with the RB1100.
I had two Kingston modules that would not reboot with the RB1000 but otherwise worked fine. One seemed to work with the RB1100. The other would not allow the RB1100 to post.
Because of these uncertain results, I made the decision to ship all my RB1100 stock without RAM upgrades even though many of my customers wanted them.
I am going to wait until the next production RB1100 is available and we can buy as many as we want. At that point, I’ll start testing RAM again.
It would have been real nice if Mikrotik engineers would have tested some modules and given a list of approved RAM, rather than leaving it up to the users to figure out.
Any chance you can disclose what particular Kingston module worked in your test RB1100 ?
The silence from MikroTik on this topic is deafening and as I have to deploy a RB1100 on the 28th which will require three full IPv4 route tables, I need something in it other than the stock 512MB DIMM.
A single module of Kingston 2GB (Kingston Part No: KVR667D2S5/2G) has been through three consecutive runs of the RouterBOARD memory test (hit ‘t’ at the serial console menu) on one of our RB1100 without errors.
I am already in contact with Janis concerning this issue [Ticket#2010052666000416] and RouterBOOT 2.27beta2 appears to have solved the problem - running it in on a production router but it certainly seems stable.
I am starting over on the RAM testing since MT has declined the responsibility. I bought 2 each of 6 different modules last week and tested them on a single RB1100. Two of the six failed immediately. Another had problems. The other three tested fine.
Since then, I bought another 25 of the modules that I considered the most likely to remain stable.
I have 50 more RB1100 arriving this weekend. I’ll be upgrading about 25 and thoroughly testing them all.
RB/1100 RAM tests by tom @ roc-noc.com June 8, 2010
Tests were made with RouterOS 4.9 using RouterBOOT 2.26
and then RouterOS 4.10 using RouterBOOT 2.27
All memory is 2GB 200-Pin SO-DIMM DDR2 667 (5300)
9 different memory modules were tested:
WINTEC AMPO Model 3AMD2667N-2G-R
passed with both ROS and RouterBOOT versions
Rendition by Crucial Model RM25664AC667
Crucial CT25664AC667.16FE
failed to post with ROS 4.9 and RouterBOOT 2.26
passed with ROS 4.10 and RouterBOOT 2.27
Crucial CT25664AC667.M16FJ3
failed to reboot with both versions
G.SKILL Model F2-5300CL5S-2GBSQ
Patriot Model PSD22G6672S
but occasionally failed to reboot both versions
PNY Optima Model MN2048SD2-667 PO:142106.1
PNY Optima Model MN2048SD2-667 PO:140373.R1005
Kingston KVR667D2SO/2GR
failed to reboot with ROS 4.10 and RouterBOOT 2.27
NOTES: Most of the RAM tested came from Newegg.com. Two pieces of every module were purchased and tested with consistent results. The one exception was PNY Optima which delivered two different RAM modules under the same part number and packaging (different PCB layout, different RAM ICs, different results).
Conclusion: The lack of compatibility with RAM modules is quite disappointing. RouterBOOT 2.27 has made some improvements in this. The initial post problems have disappeared. We ended up buying 20 more of the WINTEC AMPO Model 3AMD2667N-2G-R and installed, tested and shipped in 20 RB/1100 on June 8th. All tested fine for boot and reboot. We ran full memory tests on all of the above RAM and they all passed all memory tests. The only remaining problem with some RAM modules is when the RB/1100 hangs on reboot. We now test all RB/1100 boards for reboot after any memory upgrade. We hope this helps others. We will continue working with Mikrotik to try and improve RB/1100 RAM compatibility.
Our memory passed multiple memory tests with RouterBOOT 2.26, however, it still caused the RB1100 to reboot approximately 10 seconds after starting a format of a 2GB MicroSD card.
This may be something you want to add to your test suite before determining 100% compatibility with a certain type of module.
Thanks but how do you know that your memory caused the reboot? And what brand and model of memory was it?
I found similar problems when formatting large microSD cards on the RB450G. It seemed like they were assigning all CPU resources to the format instead of making it a well behaved lower priority task.
One thing that I found was that all of the tested memory passed the MT memory tests found in the RouterBOOT menu. But many of them still hang during a reboot. I still suspect that it is a code (timing) problem in RouterBOOT rather than a memory module problem.
We had similar problems and issues with the RB1000 and RAM upgrades.
