Hi all,
I’m trying to move over to a Wireguard VPN for remote access to the management VLAN (VLAN10) with a client in the 10.10.0.0/16 subnet. I currently have an L2TP connection which only allows me to access the gateway/VPN router.
I’ve set up the Wireguard Server with public key, and created a peer with all the necessary details, and I can connect/handshake from the Wireguard client running on Win11, however there’s no downstream traffic received at the client (0 B received). Really oddly, if I change the firewall rule for WG UDP traffic on port 13231 to DROP rather than accept, the connection is still established.
Router config as follows:
# 2025-02-26 21:04:20 by RouterOS 7.18
# software id = E75X-80RJ
# model = RB1100Dx4
# serial number = XXXXX
add arp=proxy-arp ingress-filtering=no name=bridge1 port-cost-mode=short \
vlan-filtering=yes
set [ find default-name=ether5 ] name=OffBridge-5
set [ find default-name=ether1 ] name=WAN1-WF900
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name="WAN3 - not in use"
set [ find default-name=ether4 ] name=WAN4-Future
set [ find default-name=ether6 ] comment=TRNK-REC-18
set [ find default-name=ether7 ] comment=TRNK-REC-21
set [ find default-name=ether8 ] comment=TRNK-REC-34
set [ find default-name=ether9 ] comment=TRNK-SPARE
set [ find default-name=ether10 ] comment=TRNK-REC-SWITCH
set [ find default-name=ether11 ] name=ether11-StaffMGMT
set [ find default-name=ether12 ] name=ether12-StaffMGMT
set [ find default-name=ether13 ] comment=\
"Legacy Interface for Lower Park far end M5 Link. VLAN20." name=\
ether13-Guest
/interface l2tp-server
add name=l2tp-in-VPN user=XXXXX
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add interface=bridge1 name=vlan10_MGMT vlan-id=10
add interface=bridge1 name=vlan20_Guest vlan-id=20
add interface=bridge1 name=vlan30_Staff vlan-id=30
add interface=bridge1 name=vlan40_CCTV vlan-id=40
add comment="WAN3 - WF 300/300 Fibre Connection" interface=bridge1 name=\
vlan90_WAN3 vlan-id=90
/caps-man datapath
add bridge=bridge1 name=datapath_MGMT vlan-id=10 vlan-mode=use-tag
add bridge=bridge1 name=datapath_Guest vlan-id=20 vlan-mode=use-tag
add bridge=bridge1 name=datapath_Staff vlan-id=30 vlan-mode=use-tag
/interface pppoe-client
add disabled=no interface=WAN2 name=WAN2GradwellSoGEA use-peer-dns=yes user=\
oldmill-Gradwell@surfdsluk
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security_Staff
add authentication-types=wpa2-psk encryption=aes-ccm name=security_Guest
add authentication-types=wpa2-psk encryption=aes-ccm name=security_MGMT
add authentication-types=wpa2-psk encryption=aes-ccm name=security_OMHP
/caps-man configuration
add country="united kingdom" datapath=datapath_Guest \
datapath.client-to-client-forwarding=no .vlan-id=20 .vlan-mode=use-tag \
installation=indoor mode=ap name=cfg_GuestWifi security=security_Guest \
ssid=OldMill_GuestWiFi
add country="united kingdom" datapath=datapath_Staff datapath.bridge=bridge1 \
installation=indoor mode=ap name=cfg_Staff security=security_Staff ssid=\
OldMill_Staff
add country="united kingdom" datapath=datapath_MGMT datapath.bridge=bridge1 \
hide-ssid=yes installation=indoor mode=ap name=cfg_MGMT security=\
security_MGMT ssid=OldMill_MGMT
installation=indoor mode=ap name=cfg_OMHP security=security_OMHP ssid=\
OMHP
/disk
add parent=sata1 partition-number=1 partition-offset=512 partition-size=\
"55 021 510 144" slot=disk1 type=partition
add name=WAN
add name=LAN
add name=MGMT
/interface lte apn
add name=dhcp_MGMT ranges=10.10.100.1-10.10.100.254
add name=dhcp_Guest ranges=10.20.100.1-10.20.199.254
add name=dhcp_staff ranges=10.30.100.1-10.30.199.254
add name=dhcp_CCTV ranges=10.40.100.1-10.40.199.254
add name=dhcp_VPN ranges=10.10.200.1-10.10.200.254
add address-pool=dhcp_MGMT interface=vlan10_MGMT lease-time=4w2d name=\
dhcpMGMT
add address-pool=dhcp_Guest interface=vlan20_Guest lease-time=1d name=\
dhcpGuest
add address-pool=dhcp_staff interface=vlan30_Staff lease-time=4w2d10m name=\
dhcpStaff
add address-pool=dhcp_staff interface=vlan40_CCTV lease-time=4w2d10m name=\
dhcpCCTV
/ip smb users
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
set *0 interface-list=LAN
add address-list=VPN bridge=bridge1 local-address=dhcp_MGMT name=SquibbyVPN \
remote-address=dhcp_VPN
/queue type
add kind=pcq name=pcq-download-guest pcq-classifier=dst-address pcq-rate=10M
add kind=pcq name=pcq-upload-guest pcq-classifier=src-address pcq-rate=5M
/queue simple
add disabled=yes max-limit=900M/900M name=Global queue=\
ethernet-default/ethernet-default target=\
10.10.0.0/16,10.20.0.0/16,10.30.0.0/16,10.40.0.0/16
add limit-at=700M/500M max-limit=700M/500M name=Guest queue=\
pcq-upload-guest/pcq-download-guest target=10.20.0.0/16
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/routing table
add fib name=useWAN1
add fib name=useWAN2
/caps-man manager
set enabled=yes package-path=/ upgrade-policy=suggest-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge1
add disabled=no interface=vlan10_MGMT
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg_Staff name-format=\
identity slave-configurations=cfg_GuestWifi,cfg_MGMT,cfg_OMHP
/dude
set data-directory=/dude/dude enabled=yes
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether6 \
internal-path-cost=10 path-cost=10
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether7 \
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether8 \
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether9 \
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether10 \
add bridge=bridge1 interface=ether11-StaffMGMT internal-path-cost=10 \
path-cost=10 pvid=10
add bridge=bridge1 interface=ether12-StaffMGMT internal-path-cost=10 \
add bridge=bridge1 interface=ether13-Guest internal-path-cost=10 path-cost=10 \
pvid=20
set udp-timeout=10s
set discover-interface-list=MGMT
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=8192 soft-max-neighbor-entries=8191
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether6,ether7,ether8,ether9,ether10 \
untagged=ether11-StaffMGMT,ether12-StaffMGMT,ether13-Guest vlan-ids=10
vlan-ids=20,30,40
# vlan90_WAN3 not a bridge port
add bridge=bridge1 tagged=bridge1,ether6,vlan90_WAN3 vlan-ids=90
/interface l2tp-server server
set default-profile=SquibbyVPN enabled=yes use-ipsec=yes
add interface=WAN1-WF900 list=WAN
add interface=vlan10_MGMT list=LAN
add interface=vlan20_Guest list=LAN
add interface=vlan30_Staff list=LAN
add interface=vlan40_CCTV list=LAN
add interface=vlan10_MGMT list=MGMT
add interface=OffBridge-5 list=MGMT
add interface=WAN2GradwellSoGEA list=WAN
add interface=vlan90_WAN3 list=WAN
add interface=l2tp-in-VPN list=LAN
add interface=l2tp-in-VPN list=MGMT
add interface=wireguard1 list=LAN
add interface=wireguard1 list=MGMT
/interface pppoe-server server
add default-profile=SquibbyVPN disabled=no interface=<l2tp> service-name=\
service1
/interface wireguard peers
add allowed-address=10.10.201.11/32 comment=Laptop interface=\
wireguard1 name=peer1 persistent-keepalive=35s public-key=\
XXXXX
add address=10.30.0.1/16 interface=vlan30_Staff network=10.30.0.0
add address=10.40.0.1/16 interface=vlan40_CCTV network=10.40.0.0
add address=10.10.0.1/16 interface=vlan10_MGMT network=10.10.0.0
add address=10.20.0.1/16 interface=vlan20_Guest network=10.20.0.0
add address=192.168.55.1/24 interface=OffBridge-5 network=192.168.55.0
add address=10.10.201.1/16 comment=WireguardServer interface=wireguard1 \
network=10.10.0.0
/ip dhcp-client
add default-route-distance=2 interface=vlan90_WAN3 use-peer-dns=no
add interface=WAN1-WF900 use-peer-dns=no
add address=10.10.0.0/16 dns-server=8.8.8.8,8.8.4.4 gateway=10.10.0.1
add address=10.20.0.0/16 dns-server=8.8.8.8,8.8.4.4 gateway=10.20.0.1
add address=10.30.0.0/16 dns-server=8.8.8.8,8.8.4.4 gateway=10.30.0.1
add address=10.40.0.0/16 dns-server=8.8.8.8,8.8.4.4 gateway=10.40.0.1
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=10.20.100.1-10.20.199.254 list=Guest
add address=10.10.100.0/24 list=local
add address=10.20.100.0/24 list=local
add address=10.30.100.0/24 list=local
add address=10.40.100.0/24 list=local
add address=10.10.0.1-10.10.199.254 list=localLAN
add address=10.10.200.1-10.10.200.254 list=VPN
add action=accept chain=input comment="allow WireGuard" dst-port=13231 \
in-interface-list=WAN log=yes protocol=udp
add action=accept chain=input comment="Allow establics, related, untracked" \
add action=accept chain=input comment="WAN2 L2TP allow" in-interface=\
WAN2GradwellSoGEA protocol=ipsec-esp
add action=accept chain=input comment="WAN2 L2TP allow" dst-port=\
500,1701,4500 in-interface=WAN2GradwellSoGEA protocol=udp
add action=accept chain=input comment="Allow all VPN traffic" \
src-address-list=VPN
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=accept chain=input in-interface-list=MGMT
add action=accept chain=input dst-port=53 in-interface-list=LAN protocol=udp
add action=accept chain=input dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input in-interface=wireguard1
add action=accept chain=input comment="accept PPP" in-interface=all-ppp
add action=drop chain=input comment="Drop all else"
add action=fasttrack-connection chain=forward comment=\
"fasttrack - disabled to allow queue function" connection-state=\
established,related disabled=yes hw-offload=yes
add action=accept chain=forward comment=related-establ-untracked \
add action=accept chain=forward comment="allow internet traffic" \
in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="port forwarding" \
connection-nat-state=dstnat disabled=yes
add action=accept chain=forward comment="MGMT to all vlans" \
in-interface-list=MGMT out-interface-list=LAN
add action=drop chain=forward comment="drop all else"
/ip firewall mangle
add action=mark-connection chain=forward comment=\
"Disabled as currently set for DUAL WAN not PCC Load Balancing" \
connection-mark=no-mark disabled=yes dst-address-type=!local \
in-interface-list=LAN new-connection-mark=viaWAN1 \
per-connection-classifier=both-addresses:2/0
in-interface-list=LAN new-connection-mark=viaWAN2 \
per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting comment=\
connection-mark=viaWAN1 disabled=yes new-routing-mark=useWAN1 \
passthrough=no
connection-mark=viaWAN2 disabled=yes new-routing-mark=useWAN2 \
passthrough=no
/ip hotspot profile
/ip ipsec profile
add disabled=no distance=3 dst-address=0.0.0.0/0 gateway=WAN2GradwellSoGEA
add comment="Disabled as not load balancing" disabled=yes dst-address=\
0.0.0.0/0 gateway=192.168.2.1 routing-table=useWAN1
0.0.0.0/0 gateway=WAN2GradwellSoGEA routing-table=useWAN2
/ip service
set telnet address=10.10.0.0/16
set www disabled=yes
set ssh disabled=yes
set api address=10.10.0.0/16
/ip smb shares
set [ find default=yes ] directory=/pub
/ppp secret
add name=squibby profile=SquibbyVPN
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/London
/system identity
set name=RB1100-Reception
/system note
set show-at-login=no
/tool graphing interface
add allow-address=10.10.0.0/16 interface=WAN1-WF900
add allow-address=10.10.0.0/16 interface=WAN2GradwellSoGEA
add allow-address=10.30.0.0/16 interface=WAN1-WF900
add allow-address=10.30.0.0/16 interface=WAN2GradwellSoGEA
add allow-address=10.10.0.0/16 interface=vlan90_WAN3
add allow-address=10.30.0.0/16 interface=vlan90_WAN3
/tool graphing queue
add allow-address=10.10.0.0/16 simple-queue=Guest
add allow-address=10.30.0.0/16 simple-queue=Guest
/tool graphing resource
/tool sniffer
set filter-ip-protocol=icmp
… and WG config as follows:
[Interface]
PrivateKey = hidden
Address = 10.10.201.11/32
DNS = 8.8.8.8
[Peer]
PublicKey = XXXXXX
AllowedIPs = 0.0.0.0/0
Endpoint = <publicIP>:13231
Grateful of any suggestions!
