RB1100AH & RB1100
Hi dude..
i was plan to purchase 2 unit’s RB11xx as the core router, but i get confused here.
The RB1100AH cost $395 & RB1100 cost $399, refer to the spec, the RB1100AH is more better hardware spec than RB1100.
But the RB411AH prices is slightly lower than the RB1100, am i getting wrong?
if not, which is better for it?
thanks.
there is no more RB1100, RB1100AH replaces it.
there are only the following, in order of price and performance:
RB1200
RB1100AH
RB1100AHx2 (will be released in 1 month)
Good day..
dear normis, where can i get such information?
and, forgive me to ask about that, your name is normis or normunds? get confused.
thanks a lot. :slight_smile:
www.routerboard.com has this information!
normis and normunds is the same name, one is just shorter.
Dear Normis..
i mean the RB1100AHx2 tech spec..
Like I said, it’s not yet released. It will be available in one month. Then you will see the specs.
I look on RB1100AH performance. From specification i see a maximum 484000pps.
I look then on a MIPS®-Based Embedded Processors CN5010 and CN5020 from Cavium, and seem that performance is more than 1milion pps.
That it’s true?
Maybe it’s possible, but the price for that CPU alone is more than the RB1100AH :slight_smile:
