RB1100AH & Routeros Issues
Hi
i have an RB1100AHx2 , need to know does it support 4.17, as its not accepting 4.17 even via net Install.
Issues been Faced with 5.xx and 6.XX are
a) Many webpages doesn’t open for few Hotpot/PPPoE users [ Have to Assign Direct DNS in order to work at client end]
b) Stops browsing for hotspot users, [Have to disconnect at re authenticate them]
These issues are persisting with both the versions.
Thanks & Regards
Sankar.S
you have to use 5.x or 6.x on a 1100.
I did not think your problem is related to 5.x or 6.x.
I have checked with others who are running on x86 system with 5.21/5.24 , issue even persist for them too. Its resolves, if i do a ping to the site which is not opening , it pings fine { ie facebook,youtube…etc} but doest load up. Tried with different browser,different system , issue is same. If DNS be configured directly on the client system it start working fine.
