RB1100AH Stopped responding
I was in the process of configuring the firewall on the router and out of the blue it stopped responding and I have not been able to connect to the router period in any means. I have hit both reset buttons no luck followed all instructions on line that I could fiend and no luck at all. I am down right now as it is and was trying to get my hot spot back up and running and no such luck. Any suggestions the last rule I was configuring was p2p block all input and output.
Any suggestions I am personally thinking something happened to the board itself but I am open to suggestions from anyone.
Chances are you made a drop all rule and you are locked out because of it. Your options are as follows:
1.) Connect to the box over it’s MAC address with either another routerboard, or Winbox
2.) Use a console cable to get into it and make the changes needed to regain access
3.) Netinstall the box and wipe out the configuration.
