RB1100AH Upgrade / Random Reboot Issues
Hi Everyone
I have a RB1100 running V6.0RC6. First of all, I can not upgrade it to RC13. I follow the normal steps:
  1. Copy the file called routeros-powerpc-6.0rc13.npk to the routerboard
  2. in a console do a /system routerboard upgrade
  3. Click yes and wait for it to upgrade, but it does not happen.
Secondly the routerboard started rebooting recently at random times. No devices on port 11-13. No recent upgrades. The routerbaord is powered by UPS and not PoE. It really just started happening for no apparent reason.
I have the router logging to a remote syslog server, but it doesn’t seem to log anything before rebooting and since it does not want to upgrade, trying an install op RC13 is also not possible I feel kinda lost.
Any help is much appreciated.
Thanks.
/system routerboard upgrade —> it is command for upgrade routerboot.
For upgrade ROS use simple:
/system reboot
Hi
Thanks for the reply. I tried that but it does not upgrade.
Here is an email from support@mikrotik.com regarding my autosup file:
Autosupout.rif file shows that the router is rebooting because of software
problems. First, you should upgrade RouterOS to newer version, the latest is
available from the link:
http://www.mikrotik.com/download/share/routeros-powerpc-6.0rc14.npk
Then report back if problem persists.
You can open supout.rif file with a viewer in MikroTik account but information
about crashes is not available to customers.
Regards,
Janis Becs
OK the upgrade to RC14 worked. I will test it now and see if its more stable.
