I´ve tried tu upgrade a RB1100AH by winbox from 5.x to 6.x. After reboot, it don´t work. There is not beep sound at start. I´ve tried to connect by serial, but i can´t.
Any idea?
Regards
Any idea?
Regards
i think you need to read manual to get serial work, without that you can’t get to see whats happens
beep sound are only then router are fully started.
I´ve tested my serial cable with a rb433ah and conexion is ok. So I think that my rb1100 needs a repair
regards
Try using the reset button to engage the backup bootloader.
– Nathan
