RB1100AHx2 After Upgrading to ROS 6.30.2
Recently i upgraded my Router RB1100AHx2 to the latest firmware 6.30.2 because in the old Firmware when i tried to create a meta router it gives the error of Insufficient Resources. Now after upgrade i am able to create the Meta Router but now another issue arised. The router is uploading 30 Mbps to 40 Mbps automatically. I disabled all the interfaces but still something is wrong.
Can i downgrade the Router to the version 6.15 or some old version? Urgent help needed.
Have you upgrade the bios to? http://www.wirelessinfo.be/index.php/mikrotik/pages/rbupgrade
Downgrade can be.
See on my website, in dutch but folow the printscreens a made
http://www.wirelessinfo.be/index.php/mikrotik/pages/downgrade
The low upload speed is an known issue and is solved in 6.31rc.
Probably the next firmware release will include the fix.
Dear Plisken !
Are you sure that upgrading the firmware will solve the issue ? My current Firmware is 3.02 and upgrade is 3.24 ?
Currently update can be seen in the image below.
You must update the bios together with routeros, that’s the best solution.
But i can’t promise that your problem is solved.
You can try this without any danger
Dear Plisken,
Problem not solved even after upgrading the Firmware of Routerboard. You can see in the image below.
If i put the version 6.15 OS in the router by simply putting the .npk file and reboot the router will it downgrade to the version 6.15 or i need some struggle to get it back to working normaly? You can see in the image above that my 1st Ether Interface is double in upload and i unplug all the interfaces still the upload is same. You can also see my Ether4 Interface named as PSEB is uploading, its the other gateway backup service but its route is disabled and still it is uploading.
You can downgrade the routerboard.
Make supout.rif and mail your problem to
support@mikrotik.com
Finally the problem is solved after downgrading to version 5.26 back. The issue was of creating Meta Router which forced us to upgrade the ROS but things gone wrong. Check the image below
Now after downgrading the issue is resolved and now the upload is OK see the image below.
When i was on ROS 6.30.2 on RB1100AHx2 the MRTG gone MAD check the image below. Prior on old ROS 5.26 it was working fine.
Yes indeed, you can told that to Mikrotik.
This is a bug.
RB1100AHx2 nominally not support virtualization.
You have tried to work around this limitation third-party applications?
I do not understand your discussion and conclusions :confused:
Bump - I thought RB1100AHx2 did not yet support virtualization (MetaRouter).
it does not, and even if something works, it is most probably broken in some way. Check in your resources, maybe you have somehow gotten the non-SMP kernel. Then MetaROUTER will work without problems (with known problems).
Hai
some bsnl websites not opening in 1100 model like as cellone.in and karnatahabsnl.co.in.so somebody can help me.
