There are 2 routers. Very similar load (20-30% CPU). One of them never activates fan, and the other never turns it off
That’s the problem. I don’t understand why?
I also have another problem: the third router. It’s not connected to the network, it’s idle on my desk now, and his fan is constantly at 10000-11000 RPMs! Why? Why 3 different routers works in different way?
The one that has not turned fans on at 50 degrees C →
open box and try to plug fan on other headers, also, try to rotate pins 180 degrees and plug them back on, if you have some other 3 pin 12V fan, you can try to attach it there, see if it works.
Third one that runs fans at full tilt - measure middle pin of the fan header (with fan attached) voltage to the ground, at low temperatures there should be lower voltage, if there are 12V please write to support for further details.
I did that a moment ago, rotated pins, tried to attach main fan to aux header and vice versa, attaching another fan and nothing worked. I also measured the voltage on the middle pin, and it was, obviously, 0V on both headers.
It seems system tries to do something with 37C sys/51C cpu, because /system health print interval=1s shows that active-fan is changing every few seconds from ‘main’ to ‘auxilliary’ to ‘none’, but nothing works (fan-speed is 0 and no fan is rotating).
[admin@yyy] > /system health print interval=1s
fan-mode: auto
use-fan: main
active-fan: auxiliary <-------
voltage: 12V
current: 715mA
fan-speed: 0RPM <-------
temperature: 37C
cpu-temperature: 51C
power-consumption: 8.5W
it seems that second board that has 0V on middle pin also has to be RMAed. Contact your reseller.
There always has to be some voltage reading between middle pin ground if header is active.
That alternation is as designed - if RouterOS detects that on one header nothing happens it tries to turn other one up, this is why you see the alternations. If you want you can change from auto to manual and then only header you set to be on will be on.
My RB1100AHx2 is at 57C cpu temperature, and none of the fans are working.
Same as chojrak11 said, the router tries to use fan main, then auxiliary, then none.
What should I do?
