Hi!
I have an RB1100AHx2 ppc based board and I testing ROSv7 with it. I can’t upgrade it with normal method because of boot error, I see this on console:
loading kernel partition 0... OK
setting up elf image... OK
jumping to kernel code
Could not mount ubifs/yaffs filesystem: No such device
[ 3.308184] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000
[ 3.315840] Rebooting in 5 seconds..
I splitted flash into two partitions and board can boot with the fallback partition, but it can’t be upgradeable with /system/package/update/install command. However I can install any version of ROS on it with netinstall.
Another interesting thing with netinstall that the only can boot on port ether13 but I must move the cable from ether13 to ether11 after netboot to continue netinstall as netinstall doesn’t detect the board on ether13. I sucked half a day until I figured this out…
