Hi folks,
I have a RB1100AHx2 and it has two fans, main + aux. At the same time only one FAN operating and I can choose between them. It has a really annoying noise ![]()
Can I chose an option to spin up both fans at half RPM but the same airflow and when one of them fault then the other doubling the RPM to provide the same airflow?
Can I set the CPU temperature threshold where the fans spinning up? Health is:
[oreggin@RB1100AHx2] > system health print
fan-mode: auto
use-fan: main
active-fan: main
voltage: 12.3V
temperature: 30C
cpu-temperature: 35C
fan1-speed: 5206RPM
Cheers,
oreggin
