rb1100ahx2 problem
Hi Guys,
I have a very strange issue with a new 1100ahx2 we installed last week. Initially the problem was not really apparent but a power outage today has shown up what is happening. After operating for only a couple of hours, the system seems to go read only, new config can be added and will function but will not be there if you reboot. I have a script that backs up the config once a day and this cannot update as it cannot write to the files section. Additionally i cannot delete the original files either, cannot create a suppout file, basically just keeping my fingers crossed it does not have another power outage until i get a replacement there.
Any ideas much appreciated.
Regards
darren
forgot to add, its running 5.13
send a support ticket to mikrotik, that’s very special problem!
upgrade the router to 5.14 may helpful.
Yes, sent a support ticket on Friday but not yet had a reply, I have swapped it out with another one today and all seems well at the moment. The original one will not upgrade to 5.14 , i will try a complete reset on it tommorow and try again.
Thanks for your response
Darren
ok, done a complete reset on the original router, installed 5.14 and all seems well :slight_smile:
