I don’t know if anyone has come across this before but we’ve noticed it on a couple of occasions with different areas of RouterOS on this particular unit.
On April 14th, we experienced a PPPoE secret disappearing from the Mikrotik
Today, May 28th, we experienced a route revert back to it’s previous setting (gateway was 10.40.3.59 prior to changing to 10.40.3.105 - approx 16 hours later it was back to 10.40.3.59).
No safe mode was in use at any point and it appears to be random as not every change is reverting.
At the moment I’ve played only with one RB1100AHx2 but I’m doing lot of test on it.. so ..many config changes..
All was fine with 5.26 ..and the same now with 6.13 (some IPsec troubles, but I’m quite sure the problem is me)
