RB1100AHX2 running on low memory
Hi all,
First time to post in this forum, I would just like to know if Mikrotik has a feature wherein you can see what is utilizing the router’s memory? We have 3 RB1100AH X2 of the same configuration however there is one router which appears to be always on low memory. Two routers are always on 1400-1600MiB whilst the other is below 800MiB.
What should I be checking first?
You can use winbox for this.
Connect to the routerboards and click with your right mouse button in the winbox menubar and click add memory.
Or you could do it via the CLI
/system resource monitor
Yes, but is it possible to know what exactly is utilizing the router’s memory? Unlike for CPU utilization wherein you can check from /tools profile
http://forum.mikrotik.com/t/feature-request-module-memory-usage-in-profile/76755/1
