RB1100AHx2 Switch1 MTU issue
I have a RB2011AHx2 ( 6.15/3.10 ) and whenever the MTU is changed on any interface belonging to Switch1 all ports drop link.
Scenario:
-ether10 is the only port in service and is on switch1
-I change the MTU on that port, it drops and I have to wait for safe mode to recover.
-I change the MTU on any other port on switch1 and the port drops..
Connected in via ether10 and try to change l2MTU on no-link port ether8
[admin@] <SAFE> interface ethernet print
Flags: X - disabled, R - running, S - slave
 #    NAME        MTU MAC-ADDRESS       ARP        MASTER-PORT        SWITCH
 0    ether1        1500 D4:CA:6D:7B:6D:15 enabled    none        switch2
 1    ether2        1500 D4:CA:6D:7B:6D:16 enabled    none        switch2
 2    ether3        1500 D4:CA:6D:7B:6D:17 enabled    none        switch2
 3    ether4        1500 D4:CA:6D:7B:6D:18 enabled    none        switch2
 4    ether5        1500 D4:CA:6D:7B:6D:19 enabled    none        switch2
 5    ether6        1500 D4:CA:6D:7B:6D:1A enabled    none        switch1
 6    ether7        1500 D4:CA:6D:7B:6D:1B enabled    none        switch1
 7    ether8        1500 D4:CA:6D:7B:6D:1C enabled    none        switch1
 8  S ether9        1500 D4:CA:6D:7B:6D:1D enabled    none        switch1
 9 R  ether10        1500 D4:CA:6D:7B:6D:1E enabled    none        switch1
10    ether11        1500 D4:CA:6D:7B:6D:1F enabled
11    ether12        1500 D4:CA:6D:7B:6D:20 enabled
12    ether13        1500 D4:CA:6D:7B:6D:21 enabled
[admin@] <SAFE> /interface ethernet
[admin@] /interface ethernet<SAFE> set 7 l2mtu=2100
Connection closed by foreign host.AFE>
The Log doesn’t show anything other than
: Device updated by admin
: ether10 link down
This however does not occur when changing the MTU on Switch2 interfaces, it does not kick me out ( although it might drop all the ports on that switch too, I just have nothing connected yet to test ( this is in a remote location ))
Help? suggestions?
In other side device support 2100?
The other side supports up to 9216.
