RB1100AHx2 vpn clients
Are there limits to the max VPN clients (PPTP for example) on the RB1100AHx2? Or is there just a pps limit for VPN traffic?
If there is a max simultaneous vpn client limitation (memory limitation for example) is this affected by whether or what type of encryption is used (obviously pps will be affected by encryption)?
Thanks!
VPN tunnels are limited by license level.
http://wiki.mikrotik.com/wiki/Manual:License#License_Levels
RB1100AHx2 comes with Level6 license so there is no software VPN limitations.
Thank you for your fast response. Has there been any load testing done to determine if there are other limits (besides licensing) to the number of VPN clients. I’m guessing available RAM would potentially be the only issue beyond the max encrypted pps. Am I thinking of this properly?
Thanks again
