What is the right way to make one 10 ports switch from RB1100? I think to include ports 5 and 10 in the bridge. Some ports should be multi VLANs (trunk port) and some should be single VLAN (access port). And I have to connect L2 part to L3 part on every VLAN.
Questions:
- Will it work?
- Are ports 1-5 (6-10) in the switch by default or I have to include them in the Bridge or make some of them as slaves for a one?
- Which port to use in order to attach VLANs for IP part? Bridge or port 5 or 10?
- Can I use ports 5 and 10 (when they are in the bridge) for L3 level (in firewall rules for example)?
- Can I use ports 5 and 10 (when they are in the bridge) for L2 level (to connect there cables)?
- What to do with ports 11-13? How to bridge multiple VLANs from them to ports 3 or 7?
