Hello, I currently have a single L2TP/IPSec tunnel set up with the RB750Gr3 hEX. AES-128-CBC/SHA1.
I am not able to get the device to pull more than ~100mbps through the tunnel. This is a limitation of the router, if I connect to the L2TP/IPSec tunnel from my computer instead I am able to transfer 300mbits which is the speed of my WAN connection.
How is the performance of the RB1100AHx4 on a single tunnel? Will it be able to handle a (L2TP/GRE/EoIP) + IPSec tunnel above 300mbps? I have been trying to research this on the forums but I am seeing a lot of mixed reports of the actual performance of these devices.
Also, I have tried to set up an IPSec only tunnel, but I am having trouble figuring it out without being able to create an interface for it. The server side has a single interface with a public IP address. With the other tunneling modes I can assign an IP on the tunnel interface.
Thanks, I see the specs, but the RB750Gr3 claims to accelerate up to 400mbps and I cannot reach that with the overhead of L2TP. So I was wondering if there were any real world benchmarks with L2TP+IPSec not just IPSec alone.
