RB1100ahX4 issues
RB1100aHx4(ARM)
v6.45.6
Problem(s)
DHCP settings are gone as well as DHCP pools and whats weird is they come and go.
Also, file exports just sits there after trying to export settings, shows (In_progress_file) in file menu.
I also noticed CPU2 running 100% Unclassified as well but has since went back to normal(Probably normal)
I have generated a SUPout file as well if anybody is interested into helping me with this.
I have not rebooted this router nor have I upgraded it to the latest revision because this router is in a impossible place to reach right now.
I am in the process of setting up a replacement router to send down there to swap out but setting may not be right and there is no one down there that knows how to set one of these up or troubleshoot if I lose connectivity.
