RB1100AHx4 problem VPN connection freez for few seconds
I have softether servers installed on few Linux servers on Ubuntu 20.04.3 LTS. Servers working in LAN on redirected ports.
I have changed router to mikrotik RB1100AHx4.
Unfortunately vpn connection drops the packets from time to time (the hole is not big for 2 or 3 pings) and some applications lost connection. Some application eg samba can work with no problems and copy of big files stay unbroken. Analyzing connections on router I see they stable and not broken.
I have really no idea what is going on. I have tried all possible setting but it’s still the same, doesn’t matter if I use udp or just tcp, if I open ports or not.
My idea is that this router is doing something what brakes communication. Changing to other router (other brand) solve the problem, but this is not my goal.
Has someone had such experience and know solution?
From softether forum I learned that this problem happened to others but still no idea.
I have RB1100AHx4 with OpenVPN and didn’t notice any drop. Mine is a simple home configuration though. What VPN protocol are you using?
Softether
So no idea ? Even mikrotik stuff ?
In this state the device is crap. Someone would like to buy ? Can sell it cheap.
Regards
