RB1100AHx4 SNMP OID
Hi All,
i try to get informations from the RB1100AHx4 via SNMP.
I try it with the oid´s which the routerboard showing to me.
[admin@NE-Router02] > system health print
            voltage: 23.4V
            current: 451mA
        temperature: 34C
  power-consumption: 10.5W
       psu1-voltage: 24V
       psu2-voltage: 24V
[admin@NE-Router02] > system health print oid
             active-fan: .1.3.6.1.4.1.14988.1.1.3.9.0
                voltage: .1.3.6.1.4.1.14988.1.1.3.8.0
            temperature: .1.3.6.1.4.1.14988.1.1.3.10.0
  processor-temperature: .1.3.6.1.4.1.14988.1.1.3.11.0
                current: .1.3.6.1.4.1.14988.1.1.3.13.0
              fan-speed: .1.3.6.1.4.1.14988.1.1.3.17.0
             fan-speed2: .1.3.6.1.4.1.14988.1.1.3.18.0
      power-consumption: .1.3.6.1.4.1.14988.1.1.3.12.0
             psu1-state: .1.3.6.1.4.1.14988.1.1.3.15.0
             psu2-state: .1.3.6.1.4.1.14988.1.1.3.16.0
See output from check_snmp ..
:/usr/local/nagios/libexec# ./check_snmp -H 192.168.141.2 -C grolne -o .1.3.6.1.4.1.14988.1.1.3.8.0
SNMP OK - 234 | iso.3.6.1.4.1.14988.1.1.3.8.0=234
:/usr/local/nagios/libexec# ./check_snmp -H 192.168.141.2 -C grolne -o .1.3.6.1.4.1.14988.1.1.3.10.0
SNMP OK - 340 | iso.3.6.1.4.1.14988.1.1.3.10.0=340
:/usr/local/nagios/libexec# ./check_snmp -H 192.168.141.2 -C grolne -o .1.3.6.1.4.1.14988.1.1.3.15.0
External command error: Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: iso.3.6.1.4.1.14988.1.1.3.15.0
:/usr/local/nagios/libexec# ./check_snmp -H 192.168.141.2 -C grolne -o .1.3.6.1.4.1.14988.1.1.3.12.0
SNMP OK - 104 | iso.3.6.1.4.1.14988.1.1.3.12.0=104
Anybody who has the same problem?
Thanks!
Markus
Try to delete the leading dot before the first digit in the oid.
i checked it without the leading dot but get the same error.
