hugal
September 29, 2017, 7:48am
1
There is 3 switch chip in the RB1100AHx4.
On this page: https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features we see chip limitaion:
Each switch chip can support up to 2048 hosts.
Does that mean that we have a limitation of 2048 devices on ether1-5 + 2048 on ether6-10 + 2048 on ether11-13 ?
Or there is no limitations, only the performances will decrease?
skylark
September 29, 2017, 8:38am
2
It is true, each switch chip has 2048 host limitation. Using SW bridge removes this limitation, but it can impact performance, because bridge uses CPU resources.
hugal
September 29, 2017, 8:58am
3
Thank you for your answer.
With this configuration, I will be using the Bridge so I won’t have this limitation of 2048 users?
/interface bridge add name=bridge1 vlan-filtering=no
/interface bridge port add bridge=bridge1 interface=ether1 pvid=40
/interface bridge port add bridge=bridge1 interface=ether2 pvid=40
/interface bridge port add bridge=bridge1 interface=ether3 pvid=40
/interface bridge port add bridge=bridge1 interface=ether4 pvid=40
/interface bridge port add bridge=bridge1 interface=ether5 pvid=40
/interface bridge port add bridge=bridge1 interface=ether6 pvid=30
/interface bridge port add bridge=bridge1 interface=ether7 pvid=30
/interface bridge port add bridge=bridge1 interface=ether8 pvid=30
/interface bridge port add bridge=bridge1 interface=ether9 pvid=30
/interface bridge port add bridge=bridge1 interface=ether10 pvid=30
/interface bridge vlan add bridge=bridge1 tagged=bridge1 untagged=ether6,ether7,ether8,ether9,ether10 vlan-ids=30
/interface bridge vlan add bridge=bridge1 tagged=bridge1 untagged=ether1,ether2,ether3,ether4,ether5 vlan-ids=40
/interface vlan add interface=bridge1 name=VLAN-40 vlan-id=40
/interface vlan add interface=bridge1 name=VLAN-30 vlan-id=30
/ip address add address=XXX disabled=no interface=ether11 network=XXX (UPLINK)
/ip address add address=XXX disabled=no interface=VLAN-30 network=XXX (MGMT)
/ip address add address=XXX disabled=no interface=VLAN-40 network=XXX (USERS)
/interface bridge set bridge1 vlan-filtering=yes
How many devices can be supported without decreasing performances?
With these features on:
50 FW rules
OpenVPN
traffic logging
hugal
October 2, 2017, 8:59am
4
More generally how many users can the RB1100AHx4 support in bridge mode ?
The CPU limitation is 5k,10k,15k connected devices ?
mkx
August 31, 2018, 7:32am
5
@hugal , did you find out the answer to your considerations? Further more … your config shows VLANs and RTL8367 switch chip reportedly doesn’t support VLANs in HW, how did you get around?
i think with more than 2.000 users on this router the last thing to worry about is switch host limit
if you need switching for that amount of host get a switch, and let the router do their job as a router
i thing rb1100ahx4 can attend several thousands of users but with a simple/optimal config and with maximum 1gbps of traffic
mada3k
November 18, 2018, 2:32pm
7
The bridging/switching is then most likley done in software/cpu.
