Hello, I own an RB1100HX2 which is running at 1066MHz, on the ROUTERBOARD—>SETTINGS, I see the CPU Frequency option, so I can change it safely to 1333MHz? It is working on an air conditioned site, thank you in advance.
First check your CPU temperature and see that is under 60°C. Then simply try it. With new frequency check system stability and temperatures again. For system stability you can do bandwidth tests with multiple computers using Btest server + Mikrotik Bandwidth APP for Windows. Check temperatures while bandwith test is running.
If temperature is more than 70°C you can consider a maintain and thermal paste change. I recommend Arctic MX4, Arctic Silver 5 and best Thermal Grizzly Kryonaut.
Regards.
Hello, I did it and I am aware of the temperature change, it only increase from 41C to 42C, thank you for your help.
