Good afternoon. Please help me, the RB1100Hx4 is running the latest stable firmware, 11 Wi-Fi Cap Ax points, also the latest stable firmware, everything is configured via the new Capsman using vlan. There is also an 11 Cap xl Ac, is it possible on the RB1100Hx4 to work simultaneously with the old Wireless package and the new WiFi package, if so, how to implement it? will a seamless network work? Tnx <3
The wifi cap XL should be capable of running wifi-qcom-ac, so you can use the new wifi CAPsMAN for them too.
But It should also be possible to run both the old and new CAPsMAN on the RB1100, see:
Vlan does not work on wifi-qcom-ac?
It does (see documentation) but not in the same way as the wifi-qcom (AC) devices.
I managed to install a new capsman on the cap xl ac. The traffic is correctly distributed over the Vlan and gets to the necessary bridges. But there is one problem, I have a hotspot configured and there is a limit for users of 10/10 M, on cap ax it works correctly, but on cap ac the restriction does not work, what could it be?
