Hi Guys anybody able to advise me i cannot get into the router to install kernel again.I had a problem updating it to 5.24 so i formatted the nand and went about trying to install it again.
I have also tried netinstall but the router does come up in the devices list however the microsd i have on the board is coming up netinstall.
Boot Server enabled Client Ip 192.168.88.1
…Lan 192.168.88.20
Any advice means plenty Kudos
RouterBOOT booter 3.02
RouterBoard 1100AHx2
CPU frequency: 1066 MHz
Memory size: 2048 MiB
NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
trying bootp protocol… failed
kernel loading failed
loading kernel from nand… kernel not found or data is corrupted
NAND size: 128 MiB
RouterBOOT-3.02
What do you want to configure?
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
f - cpu frequency
r - reset booter configuration
e - format nand
w - repartition nand
g - upgrade firmware
i - board info
p - boot protocol
b - booter options
t - do memory testing
x - exit setup
your choice: b - booter options
Select which booter you want to load:
- 1 - load regular booter
2 - force backup-booter loading
your choice: 2 - force backup-booter loading
RouterBOOT-3.02
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
f - cpu frequency
e - format nand
i - board info
p - boot protocol
b - booter options
x - exit setup
your choice: exit
writing settings to flash… OK
RouterBOOT backup booter 3.02
