RB112 and RouterOS 3.30 - disable TLS - for SMTP how?
hello there,
i use a prette old routerboard (rb112) for monitoring serial connected an USV.
the script checks every minute the state. - when some threshold exceeds the board
should send an email. - since i have upgraded to 3.30 the mail-sending mechanism doesnt
any more working.
i found out there is TLS implemented. - since i dont like creating an certificate (cpu load etc)
i wondering if there is an simple way to disable TLS on the RB? (since the mailserver advertises
TLS)
any idea how to disable TLS for mail?
thanks!
chris
Chris, please clarify your issue. Post us screenshot as well.
sergejs -
Sergejs - show a screen shot of what?
Steger is correct, I am using a Linux box for my mail server and have RBs all around the world sending email via a mail server. Now that ROS 3.30 uses TLS the RBs seem to want to answer the mail server query with requesting tls service for smtp… I use smtp-auth on, in my case, port 587, I don’t use tls for my auth port (587), nor do I want to start.
Anyway - since ROS 3.30 no emails are being processed from the RBs. All my (mail server) logs show that the RBs request tls, and since I don’t support tls on port 587, the server (my mail server) discconnects the RBs.
Basically the issue are;
Most of us use smtp-auth on a particular port for email from RBs.
Many of us do not use tls (for various reasons).
ROS 3.30 insists on using TLS to send email to a server - anyone that has a mail server that does not (use or support tls) can no longer send email from an RB with ROS 3.30.
We’s like to see this fixed. It (smtp-auth) worked fine in ROS 3.24
please upgrade to newer version.
in 3.30
/tool e-mail> send
body  file  from  password  server  subject  to  user
in 4.6
/ tool e-mail send
body  file  from  password  server  subject  tls  to  user
in 4.6 you have to expicilty set your LTS behavior
I don’t want to upgrade to 4.6 - it isn’t stable enough for me to upgrade a few thousand units.
‘You’ guys broke smpt after 3.24, so why can’t you go back and fix it?
When ROS 4.x is stable enough - I’ll switch over.
It is not related to the topic question, but please be more specific about the instabilities you have with version 4.6
sergejs -
The last I read the new userman is still in beta, and I am still seeing several posts regarding issues with it. So until userman is stable under ROS 4.x then I won’t be switching the couple of units that are the base Usermanagers for a couple networks over to ROS 4.x
Hope that answers your question…
Off topic, so slap me later. Just wanted to say hi to Thom “galaxynet” Lawless. Thanks for the lesson in natted nets. I have not forgotten… :smiley:
