RB112 / RB532 client/bridge Problem
I seem to be having some trouble keeping RB112’s connected to an AP which have no problems with WRAP boards. I’ve played with setting according to some topics. Also, i’ve heard rumors about problems with mikrotik 532 and 112 bridge problems. Anyone else having similar problems with 112 and 532 RBs?
What are the problems with bridge on RB532 and RB112 ?
Probably, you could paste/show AP and Station configuration (wireless configuration).
Wireless bridge setup should work fine, however remember that you cannot bridge mode=station, WDS is implemented for such purposes (use mode=station-wds instead).
So you’re saying you can’t put a client rb112 in station mode, then bridge it for the client’s router? That doesn’t make sense. Also, station-wds seems like it would broadcast like the wds-slave mode. Am i correct?
  1. Client wireless interfaces (e.g. mode=station) don’t support bridging, it’s 802.11 limitation.
  2. ‘Station-wds’ interface is working as a station, but can communicate with WDS peer. (‘station-wds’ supports bridging, you have to remember that WDS needs the same frequency channel usage at both ends).
‘wds-slave’ is almost the same as ‘ap-bridge’, but ‘wds-slave’ adapts to WDS peer frequency.
