The seemingly simple goal is to connect to a RB112 2.9.40 via the serial port.
I lost ethernet communication with it during initial config. Only the blue LED is lit. So, I thought I would try a net install.
115200bit/s, 8 data bits, 1 stop bit, no parity, hardware flow control.
From the Serial Console I can watch the RB boot up and ask for a log in, but it does not appear to be receiving my keyboard input.
Searching for the cause I have tried:
- 4 different DB9 to DB9 Nulll Modem Cables - same result.
- Tried to access serial port on two other good working RouterBoards - same result.
- Tried using HyperTerminal serial connection on two different notebook computers - same result
I have searched through various other “serial console” postings without finding an answer…
I must be making some dumb MT newbie mistake here… what is it?
