Hey fellas,
my RB112’s with 2.9.38 will not retain time/date after a reboot. have you seen this before? Any workaround?
Cheers!
Hey fellas,
Cheers!
Use TMZ server to share the time/date data, and a small script can sincronize them with the RB family
None of the RB keep the time/date information after reboot
Thanks for the tip.
My RB230s keep the date/time after reboot. Only the rb112’s are giving me a problem.
I don’t suppose you have a script handy to do this? I would do it if I knew how. Thanks.
Configure NTP Client on the RBs and point them to a valid time server
I thought I tried that, I will experiment today. Thanks all.
RouterBOARD 230 has internal memory to save the clock configuration. RouterBOARD 100 board needs NTP client, it has to work fine to maintain correct clock configuration.
