RB1200 after bootp from netinstall: FATAL ERROR: no network card found
Hi!
RouterBOARD 1200
netinstall 6.30
From console RB told me Kernel panic… etc…
I use last netinstall from mikrotik downloads. Version RouterOS 6.30.1
My OS winxp sp3.
RB take ip from bootp server netinstall, but:
RouterBOOT booter 3.10
RouterBoard 1200
CPU frequency: 1000 MHz
Memory size: 1024 MiB
NAND size: 64 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand… kernel not found
Please, check ethernet cable…
trying bootp protocol… OK
Got IP address: 10.10.10.11
resolved mac address 00:23:8B:C3:BB:4E
transfer started … transfer ok, time=2.24s
setting up elf image… OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
Press ENTER to reboot
Restarting system.
Whats wrong??
I have exactly the same problem now - the old RB1200 is working, but I am moving it from one customer to the new one, so I’d like to netinstall it. I tried netinstall 6.30.2 and also 6.31rc11, the same problem:
RouterBoard 1200
Memory size: 512 MiB
NAND size: 64 MiB
Got IP address: 10.112.11.3
resolved mac address 1C:6F:65:C5:1D:47
transfer started … transfer ok, time=1.58s
What’s wrong?
Seems like netinstall 6.30.x is broken. I’ve downloaded the old netinstall 5.26 and this is working. Unfortunately, the old netinstall can not upload the new RouterOS 6.30.2, so only option is to install the old 5.26 and then update to 6.27 (I don’t know why this version is provided by System Packages Update) and then to 6.30.2. It was working fine for me, but I think Mikrotik guys should fix that…
EDIT: Seems that 6.29 is broken too - the last usable version is 6.28 (http://download2.mikrotik.com/routeros/6.28/netinstall-6.28.zip) - it can be used to install RouterOS 6.30.2 too
