RB1200 CPU Speed -- Inconsistent info here and on the web.
The title says it all, but to be more specific: Routerboard.com says 680Mhz in the summary, but 1066Mhz in the block diagram. Posts on here from people with it say 1Ghz, and looking up the CPU part # says it’s 1Ghz as well, yet a seller site says 680Mhz. I figure it’s actually 1Ghz and the sellers are just copying (bad?) info from the routerboard.com summary, but I wanted to finally get to the bottom of this after a friend and I were arguing about it.
Some links:
http://routerboard.com/RB1200 - 680Mhz
http://i.mt.lv/routerboard/files/Block-RB1200.pdf - 1066Mhz
http://www.acalbfi.com/uk/Semiconductors/Processor-Microcontroller/PowerPC/p/PowerPC-Power-Optimized--General-Purpose-SoC-Embedded-Processor/0000001B21 -1066Mhz
http://forum.mikrotik.com/t/rb1200-after-bootp-from-netinstall-fatal-error-no-network-card-found/89779/1 - 1Ghz/~1066Mhz
http://www.flyteccomputers.com/details.cfm?wid=1117&wb=RB1200 - 1066Mhz
Thanks!
It depends if you understand what “nominal” mean, and on the memory used:
For 333MHz DDR the RouterBOARD work at 666MHz
For 400MHz DDR the RouterBOARD work with multiple choice: at 800MHz 1000MHz (default) or a 1200MHz
For 500MHz DDR the RouterBOARD work at 1000MHz
For 533MHz DDR the RouterBOARD work at 1066MHz
Forum became so boring idle rextended decided to reply to a 5 year old unanswered question…
Oh… :laughing:
Hey, I still appreciate the effort :slight_smile:
