I have around 10 simple queues, they work great. Router is RB1200 OS 6.0
A couple of days ago they all disappeared from the GUI - webfig and Winbox - but they are still functioning and I can see they still exist by checking in the CLI/terminal.
Is this a known issue, or something I have done makes this happen? I will admit screwed 1 queue up, I forgot to define the target so target was 0.0.0.0/0 - I realised this and 30 mins later when I tried to delete it the queues were gone. So I deleted the queue via terminal. The other queues did not re-appear.
How do I get them back?
If I reboot the router (tricky, need to book downtime) and they come back, are they likely to disappear again? Or should they be ok so long as I don’t screw up any more queues?
Thanks for any comments.
Guy
