rb133, just clicked disable ethernet and im screwed...
Just got a new rb133 out of the box and was in the main screen and i accidentally clicked disable for the ethernet and now i am locked out. Is there any way to save it? I had no wireless card in it and its a 1 port ethernet. should i throw it? send it back to wisp router?
Ok i just got back in, i was looking ont he board and there was a jumper that was open, it was labelled soft reset. With the device off I put the jumper in the closed position, then powered on. Then after a min or two I powered it off and put the jumper back open Powered back on and it was reset, MIRACLE!!!
Hai,
Try it with serial null modem cable and HyperTerminal Windows will help you...too :wink:
regards
Hasbullah.com
and RB133 has two more Ethernet interfaces (unless it is RB133c) you can connect to them same way as to first port.
