RB133 only have 11MB free space, can not upgrade
Hi there,
One of our client using RB133 and the free space on the router is only 11.8MB where as fas as I know it should be about 20MB or more.
no proxy setup so far.
Can someone let me know where and how to check and do some more free up ?
Paul
If by ‘can not upgrade’ you mean that you’re trying to upgrade to a more recent version of RouterOS, I would simply suggest you back up the files in the file system, take a config backup via “/export” just in case, and use NetInstall to overwrite the file system with the upgraded version while checking the “keep configuration” checkbox (though you’ll have a backup of the config if something goes wrong).
Thx for the response.
I did think the same thing too to solve the problem.
but the other problems are :
  • the client connected via Ku Band vsat with latency about 700ms from my end.
  • the distance is more than 200KM from my place and we are separate by sea; no land transportation.
  • public transportation available only once a week; if I go there than must stay for a week.
My point is, how to free up more space so I does not need to go there ?
Just find out last late night; the user manager backup take 5.5MB space. then how much the original space taken by user manager ?
Paul
