RB133 process TOO HIGH
Dear,
I have a link with ± 2Mbps half.
I use RB112 with 2 CM9 cards with 2 nstreme + 2 eoip-tunnel and works fine on 2.9.43 (CPU ± 42%).
I change the RB112 by RB133 with 3 CM9 cards with 2 nstreme + 2 eoip-tunnels + 1 AP (CM9 number 3) + NAT.
The CPU USE is 100% busy. When I disable CM9 number 3 and disable NAT end disable ALL FILTERS in Firewall CPU USE stay ± 98%.
Whats wrong with RB 133?
What can I do?
Downgrade it´s a good ideia?
Tks alot,
Ademir Peixoto
Comics...
see this!!!!
ip address print
ADDRESS NETWORK BROADCAST INTERFACE
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
100% busy its that!!!
Ademir Peixoto
I guess you forgot also to put proxy, dhcp, ntp and few more things :slight_smile:
RB133 - CPE, i dont think it will handle such load.
