rb133c as wireless ptp bridge?
I’m setting up a point to point shot, 7 miles, SR9.
Will RouterOS level 3 allow this? or do I need to get level 4 for this? This is just my initial test shot, need something working to show the investors.
You can do this with a 24 hour free license if you can get your investors to show up within 24 hours.
rgds/ldv
Level 3 will do a single point to point (mode=bridge instead of ap-bridge).
Would you ind sending me an email at scott@ my domain brevardwireless.com
You are just around the corner and I’d like to speak briefly with you if thats possible.
Thanks for your time,
Scott
Cool, thanks guys.
The demo version won’t cut it. I’m certain I can do the shot and so are they. The problem I need to address is stability and maintainence required.
I need to say “yep, its been up a month without so much as a hicup” or “I’ve fixed every problem within x hours during the testing”.
