thanks for your answer. I downgraded successfully to 3.23, then the old key has been requested. From this point I’m still unable to download to 2.9.51 ; the same error: broken package.
I have a RB133C with FW2.9 and had ROS4.2 installed. I have saved the 2.x license for this board.
I used the Netinstall on 4.2 and tried to load 2.9.43, but it failed (timeout).
I used the Netinstall on 4.2 and tried to load 3.30, worked.
Downgraded FW to 2.18
I used the Netinstall from 3.30 and tried to load 2.9.43, but it failed (timeout).
Loaded my old Key from 2.x
Tried to down grade, didnt take.
I used the Netinstall from 3.30 and tried to load 3.0rc1.
FTP 2.9.43
Downgraded to 2.9.43 successful.
I am sure you could simplify this but this worked for me.
finally it seems I get working the RTS-CTS with ROS 3.28 and wireless-test package with NS5 clients. The issue seems related with the “Default forward” which was active because I need STA to STA communication. I rewrote the network addressing scheme in order to route instead bridge the communication between STAs (the AP must route) and it is now working.
Thank you everybody for your assistant
Regards
Antonio
