RB133C install problem
Hi to all
after nand erase (because impossible to reset password from my old provider) I can not install RouterOS 3.22 with netinstall 3.22
here a copy&paste from hyperterminal
software-id: 1GY0-3TT key:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Waiting for installation server...
Found server at 00:50:56:C0:00:01
Formatting disk..........
installing system-3.22 [                                                    ]
At this point a program show a error message box and after a few seconds hyperterminal show a message below
FATAL ERROR: bad network connection
ERROR: installation of system-3.22 failed: broken package
WARNING: package system-3.22 onuninstall script failed
Press ENTER to reboot
ø
RouterBOOT booter 2.18
RouterBoard 133C3
CPU frequency: 175 MHz
  Memory size:  16 MB
Press any key within 2 seconds to enter setup..
kernel not found
trying bootp protocol..........................................................
When I close netinstall messagebox error, a program close and lose all configured parameters.
PC and routerboard are properly connected to 3com switch and nullmodem cable is the same I normally use to configure other devices. My computer is a XP SP3
Someone can help me (sorry for my little english)
Eliminate the 3com switch and plug directly into your laptop ethernet port.
Also make sure that your ethernet MTU is set to 1500 and not anything less.
Tom
Tank you very much r0c, problem solved and routerboard full operative :smiley:
Tomorrow I go to install this routerboard (to offer free internet connectivity trough a italian WISP “Air2bite”) on a camp in Abruzzo - Italy (where there was an earthquake) and I thank you on their behalf
