rb133c level 3 to level 4?
excused my English
hi
i’m italian
i have buy one routerboard 133c..
it is possible change the level3 to level4 ?
naturally acquiring the licence level4
thank you for help me
send me solution at maxcare73@yahoo.it
:confused: :confused: :confused:
Yes, I did it. I had some issues though, I think if you are going to use the feature of level 4 you should buy RB133 anyway - same price and you get twice the memory. But to answer your question, yes you can upgrade the license.
Scott
