If I used the 2.4 GHz (turbo mode) in a Mikrotik system (two bridges each with one RB133C and, obviously, one R52), what throughput should I expect?
Regards.
Regards.
I tried this and its the same than normal mode ![]()
UDP max 25Mbit/s
Did you get that result in half duplex mode?
Regards.
Did you selected right channel to turn on Turbo mode in 2.4GHZ ?
I’ve expierienced that using Turbo (wide channel) is not quite well idea, cause interference from other wireless equipment. It’s better to use 5GHZ band to provide much more quality links - especially when 5GHZ channels doesn’t overlap each other. It means that you have all size channel (20MHZ) to use for data.
