All I’ve found for the RB14 is:
“Up to 2.5w of 3.3v power supplied to Mini PCI card”
Anyone know if this is per slot, or total..
per slot.
If you will look corrrectly, there is a note “Should not be used with SR5 or SR2 400mW miniPCI!”.
You cannot use regular RB14 with 4 SR wireless cards, however you can use two SR wireless cards, plug them to the one side of the RB14, either RB14 might be damaged.
4 R52 or any other regular wireless cards might be used without any problems.
