Right now I have a CM9 in an RB14, with a pigtail and small antenna connected to it. I’m using a Belkin 802.11b/g usb adapter on my desktop. I’m getting an excellent signal (48 SNR). (We’re doing this indoors while we test.) Ping times are great. We’re seeing 1 to 3ms…and out of no where, 1,000ms or higher. We’ve moved the hard drive and RB14/CM9 to another PC and it’s still doing it.
Any help is appeciated.
I’m sorry, I forgot to mention, we’re running the CM9 in B-only mode.
I’ve messed around with the settings when I had it on both computers, still no luck.
I was pinging the AP (my computer[usb adapter] ~~~ mikrotik pc[rb14/cm9]) and it’ll ping about 60 times at 1 to 3ms and then jump to 1,000ms or higher (give or take about 300ms) and go back to pinging another 60 times at 1 to 3ms.
Is there anything I can tweak? Is there some sort of RTS setting on mikrotik?
0 name="wlan1" mtu=1500 mac-address=00:0B:6B:4D:03:C0 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="000B6B4D03C0" mode=ap-bridge ssid="atheros" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2437 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=indoors tx-power-mode=default noise-floor-threshold=default
periodic-calibration=enabled periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-b wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=10s default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no
Anything suggested, has probably already been tried. The current exact configuration is above.
