RB14eU hardware compatibility issues[solved]
The RB14eU ( https://routerboard.com/RB14eU ) for some reason will not work with an Asrock n3150m ( http://www.asrock.com/mb/Intel/N3150m/ ). I am unsure if I should pursue asrock compatibility bios bug reports? attempt to alter my bios?
Get a different motherboard and hope it works with another low wattage board with a 3150 ( asus? ).
Has anyone had this card working with Braswell?
Asrock tech support suggested I use windows, so I installed windows just to prove that no device shows up whatsoever in devices.
This card worked fine on a 990fxa-ud3 gigabyte motherboard for testing ( I thought I had a dead card ).
I have attempted it in every pci slot with no other cards present. Maybe there is a bios setting that could help for which I am unaware of? Or a hidden bios menu? Weird uefi thing?
I will try every suggestion.
Solved the problem by downgrading the bios on n3150m from 1.40 to 1.10. Card is detected on every boot. It is now 100% clear that this is an asrock bios issue.
