RB150 upgrading
Hello;
While upgrading from 3.12 > 3.20 from within Winbox I issued a shutdown command.
When he RB150 reboot I get nothing. When I connect a serial cable I see…
RouterBOOT booter 2.14
RouterBoard miniROUTER
CPU frequency: 175 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
System halted.
I am not sure how to unhalt the system. Anyone else ever encounter this ?
try Netinstall with the same upgrade packages, it will revive it.
http://wiki.mikrotik.com/wiki/Netinstall
Edit: I see you are running a very old Bootloader (BIOS) version. After Netinstall has revived your routerboard, upgrade the bootloader too with the command “/system routerboard upgrade”
Normis;
Thank you worked like a champ !!!
