Oh crap…
I am a GUI guy. What is not thoroughly explained in the visible Interface, I will most likely never bother to use, or find out how to use. Call it the Microsoft effect or whatever. Sorry, but true. So far.
After looking around a bit I decided upon some (IMO) heavy stuff to control my home network. I also need to learn so I figure that while I learn setting up my net, I will have use for at work. A common and simple approach that has served me well so far.
So I got this router and downloaded Winbox. Then I downloaded the manual. And started Winbox. Hmmm…“where can I do this”…“where do I do that”…“must be a simpler explanation”…“manual only refers to commands!!!”…HOKAY. I am in waaaay over my head.
Eventually I will figure it out, but I find so many features and functions that I do not know anything about (and I seriously mean ZERO knowledge) that I do not even dare touch the stuff. I am happy the internet is working. Maybe I should rephrase “happy” with “lucky”…
As you can see I have two options:
- reinsert my D-Link Router (which basically sucks but I can do some stuff in it knowing what I am doing)
- start a flak fire of questions here and require explanations that imply [Click there, fill in that value there and hit that button]
I am giving the latter a chance. Sorry Mikrotik. Do not mean to bother you with my incompetence, but your manual and interface approach asks for it.
Task 1
Change the default gateway and IP range of my network
Why? Cause I want to.
The default gateway is 192.168.88.1. The distributed IP’s range is a mystery. I do not understand why it says 192.168.88.1/24. What does the /24 stand for?
So how do I change the default to 192.168.99.100 with a range up to 192.168.99.110? Under DHCP Server? So what is IP ARP? Should I set my default values there instead? What does broadcast mean in that context?
Task 2
Port forwarding to DDNS and firewall ruling.
This should be pretty simple. After all I have done it many times. On the D-Link. But when I look it up, again, 90% stuff I do not understand or even know whether I should use it or not. I read the Firewall and QoS chapters several times but I cant figure it out. Service ports? Well, yes I grasp the basic concept, but does it mean that if I list one port there it would be open for the entire network? And why so many options…?
Quick Setup Guide
To add a firewall rule which drops all TCP packets that are destined to port 135 and going through the router, use the following command:/ip firewall filter add chain=forward dst-port=135 protocol=tcp action=drop
To deny acces to the router via Telnet (protocol TCP, port 23), type the following command:
/ip firewall filter add chain=input protocol=tcp dst-port=23 action=drop
To only allow not more than 5 simultaneous connections from each of the clients, do the following:
/ip firewall filter add chain=forward protocol=tcp tcp-flags=syn connection-limit=6,32 action=drop
That above is pretty clear and I managed to find the correct settings in the Firewall to actually believe it was correctly set up, but what if I want to specify that all connections from a certain local IP via the port 4455 are to be trusted regardless of protocol?
The DDNS has its own little application, it seems. But I can not find it. The tool dns-update command works, but I fail to see if it stores any information to be used by the router anywhere.
sigh…I rest for now. So who votes for my D-Link? ![]()
