I trying to connect RB2011UAS-2HnD-IN and APC Smart-UPS CS 420.
I have a Cisco Roll Over Cable RJ-45 - DB9F.
What pinouts to make a Cable like RJ-45 - DB9M? Or to make a adapter DB9M-DB9M with original Cisco Roll Over Cable RJ-45 DB9F?
I’m currently to get an APC USB UPS working together with an RB2011. The same UPS works like a charme with the same cable connected to a RB411. I think it might not be the cable, but the RB2011 that is causing the problem. Only just a guess! ![]()
KR,
uebi
Deleted because not related.
[admin@hvozdany-ar01.sporknet.cz] /system> /system resource print
uptime: 46m36s
version: 6.7
build-time: Nov/29/2013 13:37:20
free-memory: 104.6MiB
total-memory: 128.0MiB
cpu: MIPS 74Kc V4.12
cpu-count: 1
cpu-frequency: 600MHz
cpu-load: 4%
free-hdd-space: 110.2MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 73
write-sect-total: 338672
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB2011UAS-2HnD
platform: MikroTik
[admin@hvozdany-ar01.sporknet.cz] /system> ups print
0 name=“ups1” port=usbhid1 offline-time=0s min-runtime=never alarm-setting=immediate model=“Back-UPS CS 650 FW:817.v4.I USB FW:v4”
serial=“4B0942P63584” manufacture-date=“2009-10-18” nominal-battery-voltage=12V
