Hi there! Last Monday I tried to set up my network, after getting help from a friendly Redditor. But I’m getting issues while setting up my RB2011UIAS-RM.
The situation
The routerboard is connected to my DSL router on ETH1, which also serves as IP PBX.
ETH2 is connected to an unmanaged switch.
ETH3 is connected to an HP 1810-24G on port 2.
The VLANS should be able to contact each other (ultimately not all VLANs should be able to communicate, but that’s another question), and each VLAN should have its own DHCP range.
The port on the HP is configured to VID 1 as Untagged VLAN, which is unused otherwise.
The other VLANS are all set as ‘Tagged’ on the HP switch.
In HP terminology:
ETH2: Untagged: VLAN104
ETH3: Untagged: VLAN1 (or none), Tagged: VLAN101, VLAN102, VLAN103, VLAN104, VLAN106, VLAN1921
Current configuration
My current config, which doesn’t seem to work:
# The variables
vlans:
- bridge: bridge-management
interface: management
vlanId: 42
ranges: [ 10.0.42.10, 10.0.42.254 ]
ipAddress: 10.0.42.1
network: 10.0.42.0
- bridge: bridge-printer
interface: printer
vlanId: 101
ranges: [ 10.0.1.10, 10.0.1.100 ]
ipAddress: 10.0.1.1
network: 10.0.1.0
- bridge: bridge-guest
interface: guest
vlanId: 102
ranges: [ 10.0.2.10, 10.0.2.254 ]
ipAddress: 10.0.2.1
network: 10.0.2.0
- bridge: bridge-prive
interface: prive
vlanId: 103
ranges: [ 10.0.3.10, 10.0.3.254 ]
ipAddress: 10.0.3.1
network: 10.0.3.0
- bridge: bridge-server
interface: server
vlanId: 104
ranges: [ 10.0.4.10, 10.0.4.254 ]
ipAddress: 10.0.4.1
network: 10.0.4.0
- bridge: bridge-voip
interface: voip
vlanId: 106
ranges: [ 10.0.6.100, 10.0.6.254 ]
ipAddress: 10.0.6.1
network: 10.0.6.0
- bridge: bridge-bedrijf
interface: bedrijf
vlanId: 1921
ranges: [ 192.168.1.10, 192.168.1.254 ]
ipAddress: 192.168.1.1
network: 192.168.1.0
# The config template
{% for vlan in vlans %}
add name={{ vlan.bridge }}
/interface vlan
add interface={{ vlan.bridge }} l2mtu=1594 name={{ vlan.interface }} vlan-id={{ vlan.vlanId }}
add name={{ vlan.dhcp }} ranges={{ vlan.dhcpRange }}
add address-pool={{ vlan.dhcp}} disabled=no interface={{ vlan.bridge }} lease-time=3d name={{ vlan.dhcp}}
add address={{ vlan.ipAddress }}/24 interface={{ vlan.bridge }} network={{ vlan.network }}
add address={{ vlan.network }}/24 dns-server={{ vlan.ipAddress }} gateway={{ vlan.ipAddress }} netmask=24
{% endfor %}
set 3 default-vlan-id=1 vlan-header=add-if-missing vlan-mode=check
add independent-learning=no ports=ether03 switch=switch1 vlan-id=101
add independent-learning=no ports=ether03 switch=switch1 vlan-id=102
add independent-learning=no ports=ether03 switch=switch1 vlan-id=103
add independent-learning=no ports=ether03 switch=switch1 vlan-id=104
add independent-learning=no ports=ether03 switch=switch1 vlan-id=1921
add independent-learning=no ports=ether03 switch=switch1 vlan-id=106
add independent-learning=no ports=ether03 switch=switch1 vlan-id=42
Any help would be greatly appreciated
