RB2011 as two separate networks with separate gateways
I like to create two separate networks each with it’s own gateway on an RB2011
I configured eth1 as a dhcp client. I configured eth2 as a master and slaved eth3-5
I setup an IP address of 192.168.88.1/24 on eth2
I setup DHCP server on eth2
I added NAT masquerading with source of 192.168.88.0/24 and outgoing port as eth1
I configured eth6 as a dhcp client. I configured eth7 as a master and slaved eth8-10
I setup an IP address of 192.168.0.1/24 on eth7
I setup DHCP server on eth7
I added NAT masquerading with source of 192.168.0.0/24 and outgoing port as eth6
The 192.168.88.0/24 network seems to work ok and I have internet access.
On the 192.168.0.0/24 network I cannot even ping 192.168.0.1 nor can I “see” the internet.
I verified I am getting IP addresses. I verified I am getting an address on eth6
So, a little understanding would be helpful. FWIW this was all done with winbox.
If you want two distinct routing environments consider assigning the interfaces into VRFs - or at least out the interfaces for the secondary group into a VRF.
http://wiki.mikrotik.com/wiki/Manual:Virtual_Routing_and_Forwarding
I actually think I got it working. Found a couple of errors but with research VRF. Thanks.
My configuration actually does not work. The local segment cannot “see” the internet. When I moved the wan and local pc between segments on the bench it seemed to work but not with both WAN’s plugged in at the same time.
MikroTik RouterOS 6.7 (c) 1999-2013 http://www.mikrotik.com/
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-public-master
set [ find default-name=ether3 ] master-port=ether2-public-master
set [ find default-name=ether4 ] master-port=ether2-public-master
set [ find default-name=ether5 ] master-port=ether2-public-master
set [ find default-name=ether6 ] name=ether6-gateway
set [ find default-name=ether7 ] name=ether7-local-master
set [ find default-name=ether8 ] master-port=ether7-local-master name=
ether8-slave-local
set [ find default-name=ether9 ] master-port=ether7-local-master name=
ether9-slave-local
set [ find default-name=ether10 ] master-port=ether7-local-master name=
ether10-slave-local
set [ find default-name=sfp1 ] name=sfp1-gateway
/ip neighbor discovery
set ether1-gateway discover=no
set ether6-gateway discover=no
set sfp1-gateway discover=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
add name=dhcp_pool2 ranges=192.168.88.20-192.168.88.254
add name=dhcp_pool1 ranges=192.168.0.50-192.168.0.100
add address-pool=dhcp_pool2 disabled=no interface=ether2-public-master name=
dhcp2
add address-pool=dhcp_pool1 disabled=no interface=ether7-local-master name=
dhcp1
/port
set 0 name=serial0
add address=192.168.88.1/24 interface=ether2-public-master network=192.168.88.0
add address=192.168.0.1/24 interface=ether7-local-master network=192.168.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
add dhcp-options=hostname,clientid disabled=no interface=ether6-gateway
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,4.4.4.4
/ip dns static
add address=192.168.88.1 name=router
add address=x.x.x.x name=unifi
add action=drop chain=input dst-address=192.168.0.0/24 src-address=
192.168.88.0/24
add chain=input comment=“default configuration” protocol=icmp
add chain=input comment=“default configuration” dst-port=8291 protocol=tcp
add chain=input comment=“default configuration” connection-state=established
add chain=input comment=“default configuration” connection-state=related
add action=drop chain=input comment=“default configuration” in-interface=
ether6-gateway
ether1-gateway
add chain=forward comment=“default configuration” connection-state=established
add chain=forward comment=“default configuration” connection-state=related
add action=drop chain=forward comment=“default configuration” connection-state=
invalid
add action=masquerade chain=srcnat out-interface=ether1-gateway src-address=
192.168.88.0/24
add action=masquerade chain=srcnat out-interface=ether6-gateway src-address=
192.168.0.0/24
/lcd interface
set sfp1-gateway interface=sfp1-gateway
set ether1-gateway interface=ether1-gateway
set ether2-public-master interface=ether2-public-master
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6-gateway interface=ether6-gateway
set ether7-local-master interface=ether7-local-master
set ether8-slave-local interface=ether8-slave-local
set ether9-slave-local interface=ether9-slave-local
set ether10-slave-local interface=ether10-slave-local
/system clock
set time-zone-name=America/Denver
/system identity
set name=BlackCanyonMotel
/system ntp client
set enabled=yes mode=unicast primary-ntp=132.163.4.102 secondary-ntp=
192.43.244.18
/system scheduler
add interval=1d name=UpdateDynDNS on-event=“/system script run DynDns” policy=
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api
start-date=aug/14/2014 start-time=17:29:42
/system script
add name=DynDNS policy=
source=“# Set needed variables\r
\n:local username "xx"\r
\n:local password "xx"\r
\n:local hostname "x.x.x"\r
\n\r
\n:global dyndnsForce\r
\n:global previousIP \r
\n\r
\n# print some debug info\r
\n:log info ("UpdateDynDNS: username = $username")\r
\n:log info ("UpdateDynDNS: password = $password")\r
\n:log info ("UpdateDynDNS: hostname = $hostname")\r
\n:log info ("UpdateDynDNS: previousIP = $previousIP")\r
\n\r
\n# get the current IP address from the internet (in case of double-nat)\r
\n/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-pa
th="/dyndns.checkip.html"\r
\n:delay 1\r
\n:local result [/file get dyndns.checkip.html contents]\r
\n\r
\n# parse the current IP result\r
\n:local resultLen [:len $result]\r
\n:local startLoc [:find $result ": " -1]\r
\n:set startLoc ($startLoc + 2)\r
\n:local endLoc [:find $result "" -1]\r
\n:local currentIP [:pick $result $startLoc $endLoc]\r
\n:log info "UpdateDynDNS: currentIP = $currentIP"\r
\n\r
\n# Remove the # on next line to force an update every single time - useful
for debugging,\r
\n# but you could end up getting blacklisted by DynDNS!\r
\n\r
\n#:set dyndnsForce true\r
\n\r
\n# Determine if dyndns update is needed\r
\n# more dyndns updater request details http://www.dyndns.com/developers/spe\
cs/syntax.html\r
\n\r
\n:if (($currentIP != $previousIP) || ($dyndnsForce = true)) do={\r
\n :set dyndnsForce false\r
\n :set previousIP $currentIP\r
\n :log info "$currentIP or $previousIP"\r
\n /tool fetch user=$username password=$password mode=http address="mem
bers.dyndns.org" \\r
\n src-path="nic/update?system=dyndns&hostname=$hostname&myip=$curr
entIP&wildcard=no" \\r
\n dst-path="/dyndns.txt"\r
\n :delay 1\r
\n :local result [/file get dyndns.txt contents]\r
\n :log info ("UpdateDynDNS: Dyndns update needed")\r
\n :log info ("UpdateDynDNS: Dyndns Update Result: ".$result)\r
\n :put ("Dyndns Update Result: ".$result)\r
\n} else={\r
\n :log info ("UpdateDynDNS: No dyndns update needed")\r
\n}\r
\n”
/tool mac-server
add interface=ether2-public-master
add interface=ether3
add interface=ether4
add interface=ether5
add interface=ether6-gateway
add interface=ether7-local-master
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=ether10-slave-local
add
/tool mac-server mac-winbox
add
[admin@BlackCanyonMotel] >
