RB2011 - big latency
I have RB2011 UAS-2HnD-IN. My wireless is running on B/G/N mode. I have connected max. 5 clients. When I try to download something over than 20Mbps via wifi, my ping to gateway is going up to > 20ms and more. What should I change in my settings? My friends tested this same on his ZyXel and he has ping still < 5ms. You can look to me by WinBox:
IP: 109.236.117.106
Pass: mikrotik
How it looks during higher traffic:
Reply from 192.168.0.1: bytes=32 time<1ms TTL=64
Reply from 192.168.0.1: bytes=32 time=1ms TTL=64
Reply from 192.168.0.1: bytes=32 time=59ms TTL=64
Reply from 192.168.0.1: bytes=32 time=40ms TTL=64
Reply from 192.168.0.1: bytes=32 time=22ms TTL=64
Reply from 192.168.0.1: bytes=32 time=82ms TTL=64
Reply from 192.168.0.1: bytes=32 time=88ms TTL=64
Reply from 192.168.0.1: bytes=32 time=36ms TTL=64
Reply from 192.168.0.1: bytes=32 time=56ms TTL=64
Reply from 192.168.0.1: bytes=32 time=7ms TTL=64
Reply from 192.168.0.1: bytes=32 time=16ms TTL=64
Reply from 192.168.0.1: bytes=32 time=236ms TTL=64
Reply from 192.168.0.1: bytes=32 time=436ms TTL=64
Reply from 192.168.0.1: bytes=32 time=2ms TTL=64
Thanks for every idea :slight_smile:
If you have clients with pore modulations connected then that could explain your latency. What is the condition of each wireless client when your having latency? You could confirm that you have both chains enabled for send and receive as well as using B/G/N. If you wanted you could disable the lower modulation rates which would guarantee better connections. With low modulations a pore connection can consume all of the wireless airtime.
Thanks for tip :slight_smile:
I’m closing access.
