Missing certs for capsman was the problem even if not used
/interface/wifi/capsman/print
;;; failed to create certificate: CA not found (4)
enabled: yes
interfaces: all
ca-certificate: none
require-peer-certificate: no
package-path:
upgrade-policy: none
Now when I created certs i have all CAPs under Remote CAP
enabled: yes
interfaces: all
package-path:
generated-ca-certificate: WiFi-CAPsMAN-CA-
generated-certificate: WiFi-CAPsMAN-
It was too fast.
Still no connection to CAPsMAN
on capsman
/interface/wifi> capsman/remote-cap/print
Columns: IDENTITY, STATE, BOARD-NAME, VERSION
# IDENTITY STATE BOARD-NAME VERSION
0 biuro_dach_ant1 Ok RBcAPGi-5acD2nD 7.13
1 dom_ant1 Ok RBcAPGi-5acD2nD 7.13
2 dom_ap2 Ok RBD52G-5HacD2HnD 7.13
3 dom_ap1 Ok RB2011UiAS-2HnD 7.13
4 biuro_ap1 Ok RBD52G-5HacD2HnD 7.13
/interface/wifi> radio/print
Columns: CAP, RADIO-MAC, INTERFACE
# CAP RADIO-MAC INTERFACE
0 biuro_ap1@XX:XX:XX:XX:XX:XX%*c XX:XX:XX:XX:XX:XX cap-wifi1
1 biuro_ap1@XX:XX:XX:XX:XX:XX%*c XX:XX:XX:XX:XX:XX cap-wifi3
/interface/wifi> print
Flags: M - MASTER; B - BOUND; I - INACTIVE
Columns: NAME, MASTER-INTERFACE
# NAME MASTER-INTERFACE
;;; no connection to CAPsMAN
0 MBI cap-wifi1
1 I cap-wifi2 cap-wifi1
2 MBI cap-wifi3
but in cap logs is connected
06:00:49 caps,info selected CAPsMAN biuro_root@XX:XX:XX:XX:XX:XX%*8
06:00:50 caps,info connected to biuro_root@XX:XX:XX:XX:XX:XX%*8
